Picture ring control
I have never used picture ring control or indicator ?
I have given a review work, a nameplate specification data is obtained from database and is stored in a global.
using proper indexing a number is given to picture ring indicator, and corresponding image is obtained.
How does this work any explanation?
How to add image to picture ring indicator?
(3,535 Views)
Accepted by topic author cancancanopen
I don't understand what you are asking here. Can you please clarify?
You copy an image to the clipboard and then you right-click on the picture indicator and select "Import Picture from Clipboard". This is in the Help.
(3,517 Views)
Thanks, i got that. I was looking for the same.
Question 1, pls forget that.
(3,513 Views)
