Need little help with labview
Heey y`all, im working with labview 8.2 and a Spider8 (data-acquisition). I use some labview vi`s which I have gotten from HBM (producer of the Spider8) to communicate with the Spider8. These labview files only have a library function node, this library function nodes makes a call to a driver from the spider8. This driver is called Spider32.dll and is located in "windows/system".
My problem is that sometimes while using the spider8 with labview I get a rather strange error, this error is in the appendix. When I get this error my program stops immediately (like pressing on the abort button), after this i can`t restart the program because everytime i try to restart it I get the same error again. The only option I have is to restart the computer/laptop, after that I can use the program again and the error is gone. This error doesn`t come everytime I use the program, just every now and then but its very annoying and has to be solved.
Hope some labview-experts can help me with this:)
Currently using labview 8.2.1
(3,211 Views)
This happens sometimes when calling DLLs in "older" LabVIEW versions.
As a first step I would pre-allocate strings and arrays you get from the dll, using initialize array or a string with the awaiting length.
Christian
(3,188 Views)
Have you contacted the vendor?  It sounds like their dll might be trouncing on LabVIEW's memory allocation.
Are you passing back/forth any large arrays that might cause a memory issue?  If so, you might try retrieving the data in smaller increments to see if that helps.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,186 Views)
both of you thanks for your reply, you are both right, the original labview file ACQread.vi (which calls the dll) is in labview 4.0 😞 i just converted it to 8.2 so i could use it. In the appendix of this post there is a library file which is in labview 4.0. In this library there is the ACQread.vi, if you take a look at it you can see that I am retrieving a large array of this dll. The array size depends on the number of channels I use and the number of values it measures per channel per loop.
Could this simply be solved by increasing the input value of initilize array function? For example: normally the array`s size is:
4 (channels) * 25 (values per channel) = 100 values per loop. Then i just multiply the 100 by 2 so i get 200 values per loop? could it be solved like this?
Thank you both! 🙂
Message Edited by Grasman on 12-08-2009 03:16 PM
(3,168 Views)
In general you have to allocate the amount of memory you get back from the DLL, so your guess could work.
But since this driver is for LV 4.0 I would contact HPM and ask if there is a newer version available.
Christian
(3,158 Views)
