Performance of state machine with enum vs string?
@rbrown_acertaralabs wrote:
I'm pasting screenshots of the VI block diagrams rather than the source code, since images can be viewed immediately in the browser.
Is there a reason you didn't post it as a snippet which is also viewable in the browser and executable code?  Or post the pictures and a zip of the source?
Message 31 of 46
(2,690 Views)
Good idea to run it with case-insensitive match. To my surprise, this made a HUGE difference and drastically increased the time required for the string case:
  • Typedef Enum = 0.853 sec per 10M iterations
  • String (case insensitive match) = 84.3 sec per 10M iterations (!)
For the string case, one of the items is set as the Default case. I have posted the above results in the latest post to this topic (along with source code).
Message 32 of 46
(2,672 Views)
I intentionally did not randomly select the strings (nor the ints from the enum) during loop execution since random selection processing would add to the processing time for both the enum case and the string case. I wanted the timing to be strictly based on the case selection logic. Thus, the string array is pre-populated and the enum int array is pre-populated. However, both are pre-populated (before the timing begins) in a random order.
You are correct that the pre-populated enum int array could have duplicates -- I have fixed this and re-posted the new results in my latest post to this topic. It did not significantly change the results:
  • Typedef Enum = 0.843 sec per 10M iterations
  • String = 11.2 sec per 10M iterations
Message 33 of 46
(2,669 Views)
Thanks for pointing out the snippet option.  I have now simply posted the entire source code in my latest post on this topic.
Message 34 of 46
(2,667 Views)
Latest results, screenshots, and source code attached.
Results:
Message 35 of 46
(2,665 Views)
Still no source code, but nice testing.
mcduff
Message 36 of 46
(2,664 Views)
see previous post for source code
Message 37 of 46
(2,661 Views)
Try it with Disable Debugging, you may be surprisedSmiley Wink.
mcduff
Message 38 of 46
(2,658 Views)
The reason for the "surprise" is Constant Folding.  Nothing is coming out of these case structures, so they will likely be removed from the compiled code when debugging has been disabled.  If there was a value that came out of the case structure and wrote to a control, then we would have a more valid benchmark.
Message 39 of 46
(2,632 Views)
@crossrulz Thanks for the explanation.
Message 40 of 46
(2,630 Views)
