ā09-16-2008 02:51 PM
I've got a Main vi which contains a tab control, each page holding a subpanel linked to a SubVI. When using the Performance and Memory Profiler my Main.vi is the only one that shows up, so the timing information isn't very useful. If I get a Snapshot while the profiler is running it shows the linked subVI's as being in memory, but doesn't show any timing information on them (All 0.0's for all vi's including Main).
Am I doing something incorrectly?
ā09-17-2008 01:18 PM
Sorry for the bump, but...
Any ideas on this? If what I'm trying to do isn't possible I'll live, but timing info on my subpanel-linked VI's would definitely be nice to have.
ā09-17-2008 06:37 PM
ā09-18-2008 11:03 AM
Looks like you are doing everything correctly. The problem is somewhere between how the SubPanel deals with VIs in memory, and where the Profiler gets its data. You should be able to see stats for your main VI once you stop it, but not the subVIs you are loading into the panel. Sorry if this isn't what you were looking for, but at least we can say that it is not you doing anything wrong. I would head on over to the Product Suggestion Center and submit this (these are taken seriously!). It's certainly a valid use case that may not have been considered yet.
Cheers,
ā09-18-2008 01:26 PM
ā09-19-2008 09:44 AM
