Perform a single task if comparing 2d arrays do not match
Hi All
Unfortunately I cannot post my VI but hopefully I can explain my problem well enough. I have a program where I poll for data every 10 seconds from my UUT. Currently I have the data(strings) being output into a 2D array. Since the array is very large, I basically want to set up my code to compare the current captured 2D array with the 2D array I captured 10 seconds ago (I am using a shift register in my loop) and save the current entire 2D array to a file only if any of the elements have changed (Specifically I will save the initial array, then continue to save each array that is different than the previous). I am not sure how to best compare the arrays. When I use the "not equal?" function, the output becomes an array of boolean True/False, and I dont know how to use a boolean array to control a case structure with my file save code. Is there something I am overlooking or a way to do this more efficiently?
Thanks!
(3,688 Views)
Accepted by davidthealias
Right click on the equals function, point to comparison mode, and choose "compare aggregates".  This should output a single true / false value.
(3,665 Views)
Wow that was easy. Thanks!
(3,660 Views)
No problem.
(3,656 Views)
