Perforce and LabVIEW 7.1 Base
Is it possible to use perforce with LabVIEW 7.1 Base? I have installed perforce  but the source code control menu does not appear.
Hernan
(2,966 Views)
Perforce is supported in the Professional version only (or one of the Pro Suites of course).
Heres a link showing the differences:
(2,961 Views)
While you have 7.1 Base, I believe you can still use Perforce for software code control.  You just do not have the direct SCC menu hook to it.  You'll have to check files in and out from Perforce rather than from Labview directly.
(2,952 Views)
