Peak picker routine
I am trying to write a routine for peak/valley detection. What I want to do is be able to scan data for a period of time (say 5 or 10 seconds) and have my routine spit out the max and min values detected during that time, regardless of level. I don't want to put in a hard threshold value as I can't say for certain what my values will be, so if there must be a threshold it has to somehow float with the signal.
I want to manipulate the data as it updates (at the 5 or 10 second interval), display it and log it to a file.
I also want to be able to have a running display of the raw data that will be updated at some fractional second interval.
Can anybody recommend which peak detector functions and/or VIs would be best for this, or better yet which example program might be the best for a starting point?
(3,098 Views)
Look at the peak detector in the waveform monitoring.  It is very nice and uses 1st and 2nd derivitives to get a good calculation of peake in a signal.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,077 Views)
Peak detect vi's will give you a datapoint that is a bit offset from your actual data values on the X-axis. Depends on whether you need your closest actual datapoint or what the peak detect vi's output.
(3,063 Views)
