Peak counting using spirometer sensor
Hello All,
I am trying to write a code where is able to read the signal of a spirometer and count the number of peaks in a certain time interval. So far, this is what I have done but I still struggling with that.
Thanks in advance!
(3,726 Views)
Please down convert to LV 2015 and share.
Not able to VIEW Code
(3,694 Views)
Accepted by topic author castrol124
There is a sample VI in the NI Example Finder called "Peak Detection and Display" that shows how to incorporate the Peak Detector.vi within LabVIEW with a while loop to count the number of peaks during a given cycle.
(3,667 Views)
Thanks for your response!  I already achieve this!
(3,654 Views)
Hi please if you have already worked on a spirometer project can you send it to me. because i have an cademic project about it,
(1,332 Views)
