Pb Auto Execution Vi : How to Edit it ???
I have developped a vi in which I set the start at open option enable, and I use the Exit Labview sub-vi at the end of the vi execution to close it entirely. It works fine, but I have found a bug in my program.
How can I edit it ?? : The vi runs at the open, and stop labview at the end.
Help is welcome.
Eddy DUCHENE
12 F Chemin de Boutary
69300 CALUIRE ET CUIRE
educhene@laposte.net
(2,996 Views)
Here's one way to do it.
Create a directory in your LabVIEW x.x directory named 'wizard', and save the attached VI there. If LabVIEW is running, you'll need to restart it, but then in the 'File' menu, you'll have a new selection named "Supress Run on Open...". Select this and you'll get a browse dialog to select the VI to open. It opens it by reference so it will not run.
This is saved in LabVIEW 6.1, but works fine on 7.0 and 7.1.
You can also open it by opening a blank new VI, drop the the vi that you wanted to edit as a subvi and opening it from the block diagram of the blank one you just created. It won't run when opened.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,993 Views)
Thanks a lot for your rapid and good answer Ed.
It works fine.
Bye
Eddy DUCHENE
(2,988 Views)
