Pause a for loop
I am trying to do something like a countdown timer. I just created a for loop and then wired its loop count to a string indicator on the screen after converting the loop count to string. And on front panel you can see one, two, three etc. But I want to pause the for loop in between. Is there a way I can do that. Thank you.
(1,492 Views)
Hi govindsankar,
Sure!
The simplest solution would call the OneButtonDialog (inside a case structure inside your FOR loop) when you want to "pause" the loop:
(1,484 Views)
The correct way would be to have a while loop and a proper state machine (look it up!).
States could be (1) idle, (2) paused, (3) counting down, etc.
Not sure why you need a string indicator to display a numeric value.
Start by attaching your VI. Make sure it has all the controls and indicators you need (start countdown, pause countdown, show numeric progress, enter target time, end program, etc.). Explain the reason for each and how it will be used during the run.
(1,435 Views)
He has 247 posts.  he should know the basics (like attaching the VI) by now.  😕
Bill
CLD
(Mid-Level minion.)
(1,407 Views)
