Pasting values only Excel
I am trying to paste some values from one worksheet in excel to another. I have no issues pasting the cells as is, the problem is, the cells which I copy have formulas in them to calcute some information for me. I would like to paste the values only. In excel you would do this by Copy --> Paste Special --> Values. I made a macro and tried to fallow it word by word. I got stuck when the paste special options surfaced. I have attached the image I hope it helps. If not simply ask for a VI and I will gladly make a sample vi.
Message 1 of 19
(6,757 Views)
I assume you are looking for the value 'xlPasteValues'.  If so, make a property node of the XlPasteTypes class and select the property 'xlPasteValues'.  You can find the other values similarly.
Message 2 of 19
(6,740 Views)
Nice! I will give that a shot and update this thread with problems if I have any.
Message 3 of 19
(6,736 Views)
Accepted by topic author MrSafe
Actually, you can just right-click on the "Paste" element, and select Create->Constant. This should create an enum constant where you can select the appropriate value.
Message Edited by smercurio_fc on 07-21-2009 03:36 PM
Message 4 of 19
(6,734 Views)
Holy ...... Thanks man.
Message 5 of 19
(6,731 Views)
I am recieving this error now. I can get it to work here and there but this error comes up almost every time.
"Error -2147417848 occurred at The object invoked has disconnected from its clients."
Hex Code = 80010108
Message 6 of 19
(6,702 Views)
Without seeing some code, all that I can do is point you to this Microsoft KB article.
Message 7 of 19
(6,698 Views)
File is attached.
**update** seems in my haste i left some files out. Sorry
Message Edited by MrSafe on 07-21-2009 05:54 PM
Message 8 of 19
(6,696 Views)
Here is the last file needed.
Message 9 of 19
(6,693 Views)
Are you trying to run the VIs independently? It seems that way since each one is opening and closing Excel. You should only be opening and closing Excel once. Thus, you should be carrying out all your operations within one VI hierarchy. Meaning either all in the same VI, or you can use subVIs, and pass the references through the subVIs.
Also, when I opened up the VIs I found property nodes and invoke nodes with some parameters not wired. I can only assume it's because you're using a different version of Excel. Microsoft changes the Excel object model with each version.
Message 10 of 19
(6,665 Views)
