Passing parameters to a remote VI and receiving data from it
Hello all,
I need to remotely control a data acquisition VI on a remote machine. For this I use VIserver. I can open and run VIs on the remote machine. But, first, how can I input parameters (from the local machine) in the remote VI (like paths and/or names for data to be stored, instaed of a window opening to ask on the remote machine)? And secondly, how can I get to see on the local machine the data that is being acquired by the remote one?
I included the example VI server and client I use, as well as an example of data acquisition VI I use.
Thanks very much for your help!
Fran
(4,011 Views)
Hmm... It looks all right with you VI server and client, but you data acquisition vi is not a good example of code (on my taste). Anyway, your client-server vi's can work in a way that they call/launch remote data acquisition vi, that vi acquires some data, stops and return it to the client vi wich can then analyse/save recieved data. It's not the case for you data acquisition vi as it supposed to run/acquire continuosly (waiting for user to press stop button). So, in order to work with this model your acquisition vi must be changed to acquire only portion of the data and return it to client by connector output.
If you want to get the data from the remote vi wich runs continuosly you must try some other approaches. It can be use of datasocket server to exchange dat
a, also queues/notifiers can be useful (but: normal LV queues and notifiers have sence only on the same computer they have been created - in order to use some similar technique you can search for remote queue project on OpenG - it seems they have something there).
Hope this can give you some ideas.
(4,010 Views)
PS:
Also, If you have LV version 6.1, this can be a good case for the use of remote panels. As I don't know how - and where - you plan to use your application I can not advise anything more helpfull.
(4,010 Views)
Thanks for your answer.
Our application is a marine surface vehicle. We therefore cannot have access to the remote machine. Several types of data will be acquired (GPS, pressure sensor,...) by this remote machine, and then stored in it.
It is linked to a laptop by a wireless LAN. On this machine we would need a VI that enables us to run and stop a data acquisition VI on the remote machine, and another that enables us to check and control different parameters (for instance, check if a light on the vehicle is switched on or not, and be able to switch it on or off at will).
How would you do this?
Thank you very much for your help !
Fran
(4,010 Views)
Ok, "How would you do this?" is a considerably big question (sometimes its simplier to make a program than explain how to do it for someone other), but I'll try to provide you with some usefull tips about what you can make to implement your application. Nearby all suggestions made by me earlier can be used for this, excluding, may be, remote panels, as you plan to use wireless LAN and remote LV panels usually consume bandwidth significally, so this is not a solution.
Anyway, you need two kind of vi's on your remote computer. First - the most simple class - are the vi's to set/get parametrs, like setting/getting lights state. Here you can go on with solution you alredy implement - your vi server/client. So you call such a vi from your laptop, its sets or gets parameter and returns its value to your application.
Second part - your acqusition vi - is more tricky and there is a number of ways to implement it. The problem you have here is similar with passing data in and out of a running while loop. The approaches to solve it are not the same, but similar in both cases - is this loop runs on the same computer or on a remote one.
1) you can use global variables, preferably so called "old style" globals to pass the data. With them you work with the same approach as with earlier mentioned vi's. Like this you can set the filename (and may be some other initial parameters) to store acquired data on remote computer.
2) you can use queue's or notifiers mechanism to do the same job. It's great when loops are running on the same computer, and, personnaly, I prefer this one, but for remote you need the remote implementation of this approach - it's available somewhere on the OpenG as I've mentioned before.
3) Finally, DataSocket server. I'm not very familar with DS, but it's looks like it is a natural and not a diffucult thing to use.
So, I consider that you make your acquisition vi - with some kind of a while loop inside.
If you prefer to use data transfer by variables, then, before launching it you supply initial parameters of your acquisition by mean of setting some "old-style" globals on your remote PC. As a global variable you can implement also your "stop acquisition" button, so remote acquisition vi will check it on each iteration. Also in a remote acquisition while loop you set the variable with the last acquired data - so you can read it with your laptop if you need (as I understand, you monitor your remote system with laptop, so you don't need ALL data to be read immediately - only to know that it is working "down there". The remote system stores all the data in a file, so you can implement lately a vi that reads and sends this file to your laptop).
Also, you can use the "remote queues" instead of variables. Good sides are that you can implement more sofisticated command interface for your remote system and it is also can be used for syncronisation purposes. Like this you can implement a "command" queue for your remote acqusition, so on each iteration you test (but not wait) - is there any new commands in this command queue (i.e. "stop", or, suppose, "change acqusition parameter") - and react accordingly. If there is no new commands, you measure new data and repeat the procedure. Like this you can implement the output queue for your data to be passed to the laptop or use a global variable.
Ok, If you have questions concerning details of the approaches described here - feel free to post here, and I'll try to supply more information.
Anyway, If you are not very familar with labview programming than I recommend BEFORE trying to build your application look for examples given with LV distribution disk, then may be try to implemet some - or all - of the mentioned approaches.
PS: here just some thoughts about the acqusition vi you supplied as an example. Here I'll try to explain why this is not at all a good example of coding.
You have two parrallel while loops running there, one to acquire data, and the other to save it. The data a passed between them by a local variable. The problem is that your loops are not at all syncronised, so one can not be sure:
1) are you save data that have been already saved (if you save data faster than you acquire it)
2) are you loose data (aquisition if faster then you save the data)
3) what will be in the case that you write in this variable the same time you read it?
In other words, we can have here the classic "run condition". You cannot be sure what is passing there in reality.
To be sure that all data you acquire will be save (and without duplicates) the queue syncronisation are much more preferrable.
Sorry for my poor english
(4,010 Views)
Something I have done in the past is to design the remote application such that it can run standalone without remote control actions. To transfer data between the remote and local machines, I then used LV2-style globals on the remote machine that are written to by the process running on that computer. To get the data back to the local machine, I use VI server to read the global from the local computer.
For one application I even created a bidirectional link in this way. The global I wrote to on the remote machine formed a command queue that the remote machine read and processed.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,010 Views)
If i understand your problem...i do the link between computers by VNC and control remotely the marine unit´s computer.
If i dont understand...sorry.
Leonardo de S. Cavadas
Maintenance Engineer and Inspection - Bureau Veritas do Brasil
Engineer Metallurgist with emphasis in Advanced Materials
Technologist in Computer Science
(3,683 Views)
