Passing of variable name to switch LEDs
That works better except now it can't find Get Boolean.vi, in the Button Check.vi...
Brian
Message 11 of 16
(973 Views)
Same problem here. Can't find Get Boolean.vi in the Button Check.vi. Anyway, thanks for all your help, pple.
June
Message 12 of 16
(973 Views)
Ahhhhh. Here is a manually generated library with my button checking VIs. Why is it that it can work fine here and not there?
The problem seems to come from having calls to the same VI from different levels of the VI tree. When I create a development distribution, links are broken. I'll bounce this one off of the NI engineers.
Rob
Message 13 of 16
(973 Views)
That works.
Let us know what the engineers come up with.
Brian
Message 14 of 16
(973 Views)
Hi Rob,
Thanks for the example. However when i tried to do some modification it keeps giving me an error at Set Boolean.vi, saying invalid parameter input. I merely input some string constant at Control Name and they prompt me this error. Why?? Is it because data string not compatiable?? Help!!!
June
Message 15 of 16
(973 Views)
Hi June,
I have the same problem, that is switching on particular LED (on front panel) using variable name. Were you able to solve your problem? If so, can you pass on a sample code.
Thanks!
Jeguna
Message 16 of 16
(958 Views)
