ā03-17-2022 10:54 PM
Is it possible to pass live DAQ data from one LabVIEW executable (acquiring data) to another LabVIEW executable (analyzing data)? If yes, what is the best practice?
What I can think of is via
1. shared variables, and
2. TCP/IP.
Any suggestions are appreciated.
Thanks.
ā03-17-2022 11:12 PM - edited ā03-17-2022 11:14 PM
Combine them into one program that uses a Producer/Consumer architecture
ā03-17-2022 11:32 PM
TCP/IP would be a better approach with higher throughput and both applications can be developed in different languages if required.
ā03-18-2022 01:20 AM
I used Producer/Consumer architecture in the DAQ module/executable, but unfortunately for this project, the DAQ and Analysis fundctions must be built in two separate executables.
Thanks.
XL
ā03-18-2022 08:40 AM
gRPC is also a good alternative to TCP/IP.
Does the data analysis have to be almost real-time or can it be like post-processing where you write data to a file and process the files later in time?
ā03-18-2022 08:58 AM
Thanks.
XL
Unless for some reason you had to use a different programming language for something, that really does not make a lot of sense but okay...
Then TCP/IP
Good luck.
ā03-18-2022 09:19 AM
I did find this white page on doing it the shared variable route. This is interesting though I am going to have to me try some things out this weekend and see what I can come up with and what other people post.
Communicate Between Multiple LabVIEW Executables Using Shared Variables - NI
I did come across some C++ posts about data between two executables seemed to take an input/output handle + some buffering and thread approach, then I see some people suggest a 3rd executable that acts as an interface between the other two that is always monitors the inputs and outputs of both executables.
I hope to get back to you with more I am super curious now.
ā03-23-2022 07:52 PM
Thank you all for your inputs.
I may have described the challenge in a wrong way. I was describing a potential solution than the actual problem.
The challenge is
1. Data acquisition and some general analysis capabilities are developed by Party A
2. A special analysis module "Module B" is developed by Party B
3. Party B dos not want Party A to have access to module B, but would like to use the capabilities developed by Party A (and Party A has to issue with that).
4. Party B will change/modify Module B frequently but does not want Party A to recompile executable every time.
I did some research, it appears to me that, instead of having two executables and trying to pass data between them, PPL+plugins may be a better way to solve the problem.
I have never done PPL+Plugin before, and would appreciate your advice.
Thanks.
XL
