Passing an array of structures to a dll
I am trying to get a dll in labview to work with my project and am having trouble getting the library node to accept one of my parameters. The function I am using is defined below with an example from the documentation. MaxDeviceLen is defined as 512. I have tried creating an array of unsigned bytes with length 512, building it to a cluster for the struct, and then building it into an array to be input into the call library node but that did not work. I have also tried converting it into an array of clusters of strings to no avail, as well as a couple of other similar approaches. Any help on this would be greatly appreciated.
(2,339 Views)
Basically that string is inlined. So you need to allocate an array of U8 bytes with n * MaxDeviceLen elements (with n being the number of array elements you want to have and which better matches the third parameter passed to DelcomScanDevices() ) and pass that as Array Data Pointer to the DLL. Then to index the i-th element to pass to the DelcomOpenDevice() function you simply use ArraySubset with the offset set to i * MaxDeviceLen and the length as MaxDeviceLen and pass this array as Array Data Pointer to the DelcomOpenDevice() function.
Rolf Kalbermatter  My Blog
(2,252 Views)
Rolf,
Thank you for your reply. I have decided to go with another function that essentially does what I want instead and is a little easier to work with.
-Martin
(2,236 Views)
