Passing a 2d array to a DLL written in C++
Hi!
I have made a DLL in C++/MFC. I have to implement a function that can
fill a LabView 2D-array with some data. How can that be done?
I suppose the function should look something like this:
int MyDllFunction(unsigned char **matrix, int width, int height)
for (int r = 0; r < height; r++)
for (int c = 0; c < width; c++)
matrix[r][c] = SomeData(r, c);
return 1;
Where should the memory of the array be declared? Maybe LabView can
allocate the memory itself and pass the function a char-array
(together with the width and height) to my function? How does it work?
Any help is really appreciated! Thanks!
/Chris
Message 1 of 8
(7,424 Views)
znakeeye wrote:
> Hi!
> return 1;
int MyDllFunction(unsigned char *matrix, int width, int height)
In fact this is what LabVIEW will generate to be passed to the DLL for a
two dimensional uInt8 array and your function will have to look like this:
matrix[r * width + c] = SomeData(r, c);
return 1;
Two dimensional arrays in C are a little underspecified. Some see it as
a single pointer with column * row elements, others as a pointer to an
array of pointers. LabVIEW chooses for the first!
The memory should always be allocated by the caller, e.g. LabVIEW in
this case. Just use an Initialize Array function to allocate the 2
dimensional array before passing it to the Call Library Function.
Rolf K
Message 2 of 8
(7,424 Views)
Rolf wrote in message news:<407b0290$0$135$3a628fcd@reader1.nntp.hccnet.nl>...
> znakeeye wrote:
> > Hi!
> > return 1;
> return 1;
> Rolf K
So basically my function is valid (although I have to sw
itch rows and
columns for a valid result) and all I need is to make a LabView
program that allocates a 2d-array and passes it to this dll function?
Thanks for the information regarding rows and columns.
/Chris
Message 3 of 8
(7,424 Views)
>So basically my function is valid (although I have to switch rows and
Well, not sure about switching columns and rows really, you will have to try this out. My change is in the type of the matrix parameter. Compare it to your original code.
return 1;
Rolf K
Rolf Kalbermatter  My Blog
Message 4 of 8
(7,422 Views)
Chris,
I just wanted to add my 2 cents on the topic. Rolf has got you down the correct path, however there is an example that I think will really help you.
It ships with LabVIEW 7.0 and can be found at C:\Program Files\National Instruments\LabVIEW 7.0\examples\dll\data passing\Calling Native Code.llb
This example shows how to pass all sorts of data to DLLs. It has the calling VI, the DLL, and the source for that DLL. In addition there is the Using External Code in LabVIEW manual.
Evan
Message 5 of 8
(7,422 Views)
Evan wrote in message news:<50650000000500000095770100-1079395200000@exchange.ni.com>...
> Chris,
> help you.
> Evan
Thanks! I'll take a look at it!
Message 6 of 8
(7,422 Views)
rolf wrote in message news:<50650000000500000084770100-1079395200000@exchange.ni.com>...
> matri
> return 1;
> Rolf K
Thanks a lot! I'll try it out. To me it seems quite strange to be
using a single pointer though. But, then again, I don't really know
how LabView works =).
Message 7 of 8
(7,422 Views)
As Rolf pointed out, this isn't a LV issue, but a C one. In C, 2D
arrays can be defined with [][], in which case the code generated by the
compiler cannot do any of the work for you. You must access the array
as a single pointer like Rolf shows. You can define the array as [x][y]
in which case the compiler knows the size of each row and can do the
math for you. Anyway, this is all C and the only reason you may not
have seen it before is because you dealt with fixed dimension arrays.
Greg Mckaskle
Message 8 of 8
(7,422 Views)
