Passing Data to SubVIs: W/O clusters?
Dear all,
I have 40ish measurement (real) values  and 30ish boolean values continuosly coming from a measurement. I need to pass them to various subVIs for processing the data. I intend to bundle this data in order to not have 70 wires an SubVI-Terminals.
What am I recommended to do?
I like the bundle/unbundle function for clusters, but any change in cluster shape during development brings a huge effort to fix all folowing VIs. This is not practical.
I could pack all data of the same type in big arrays, but i would have to manually "unbundle" them via "index array" (no? is there another way?)
What is a practical solution to this?
Thank you!
(2,843 Views)
Accepted by topic author OPCer
Hi OPCer,
use a cluster with two arrays. One array holds "real" (aka float or DBL) values and the other holds the boolean values…
Well, when using clusters you should always think of type definitions! There's a reason we have those…
There are key-value datatable implementations available. You may have a look at them…
And yes: there's no other way then using IndexArray to get elements from an array (apart from using autoindexing in loops).
(2,834 Views)
You could use Variant Attributes to hold all of your values.  They use a string as the lookup and then you just supply what the data type of that attribute should be.  It is a very powerful mechanism.
Though, I am wondering if you should be breaking up your code better.  That many IO typically means multiple systems or subsystems.  You should break up your data to mimic those.
(2,808 Views)
