FPGA DO negative offset
I'm Sean.
I'm using USB-7856R to test comparator VI generaing digital output.
Though I set FPGA's DO to have 3.3V output, it gives negative offset, the green signal lines shown in the picture below.
Finally, the positive peak is just around 1 V, not enough to connect other switching devices.
What should I do to have DO between 0 and +3.3 V?
Thanks in advance,
Sean Ahn
(3,108 Views)
Did you connect the Digital Ground to your system ground?
(3,086 Views)
