Pass reference to shared variable
I use two shared variables within a loop where I write to one and read from another.  I need to repeat this loop 5 times but each loop uses a different pair of shared variables.  These variables are shared between a vi on the computer and a cRio.
It would be ideal to incorporate this loop into a subvi where I can pass a reference to the two shared variables into and then read and write to threw those references.  Then I could just call that subvi 5 times, instead of copy and paste the loop 5 times.
Is there a way that I can accomplish this?  I can't seem to find an example that would accomplish this.
(4,244 Views)
Accepted by topic author GreenRiver
If I understand correctly, you could use the programmatic access mode to Shared Variables and it would work.
https://www.ni.com/docs/en-US/bundle/labview/page/reading-and-writing-shared-variables-programmatica...
(4,227 Views)
Yes, this is what I was looking for, thank you.
(4,206 Views)
