Event Case Structure Not handling XNET Frame selection Value Change Events
     I am working with XNET Front Panel controls and am trying to get a XNET Frame Control value change to trigger and Event Structure event and it doesn't seem to be working.  I can get it to work with the Interface Control but Frame Controls don't seem to register with the Event Structure Value Change event.  Is this a bug?
(4,236 Views)
Can you post your code, or a picture of your code? I've never seen this problem personally.
(4,226 Views)
Here is a snippet of code that I just made up that shows whats going on.  Like I said if it wasn't for the change database control event working I would say all controls that have to do with an XNet Database were suspect.  This is LV 2012.
(4,215 Views)
Known bug, with workaround.
https://lavag.org/topic/18748-labview-2014-bug-with-event-structure/
CAR #426378
In LabVIEW 2015 with XNet 15.0 this still behaves this way.
(4,206 Views)
Basically I got around the problem with just timing out my event structure and polling the controls and comparing them with previous control data which I already had placeholders for.  It's kind of loose because of using processor instead of just waiting until a change event occurs but it will have to do.  Thanks for you help all.
(4,184 Views)
