Pass data between two VIs running in parallel
Hi girish,
@girish_jadhav wrote: 
If both of these VIs are not in a single VI how can we use queues or notifiers? To use them both of these loops should be in single VI as far as I have understood it.
You can open the same named notifier/queue in each of those VIs…
Message 11 of 12
(592 Views)
You can also launch all of the subVIs from a single launcher and pass in the queue/notifier references. The top level could create them. If the top level remains running it can also be the one to destroy the queue when th eapplication shuts down.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 12
(588 Views)
