Pass a datalog or GOOP refnum to a DLL
How does one pass a datalog or GOOP refnum to a DLL? I have VI's utilizing GOOP that I want to convert to a DLL. I want to create a refnum on the first call to the DLL and pass it to subsequent calls to the DLL.
(2,681 Views)
I am assuming that you have a few GOOP VIs that you have converted into DLLs and want to pass the GOOP reference from one dll call to the next.
I managed to pass the refnum from one dll call to the next by using "Adapt to Type" for the type of the parameter when configuring the call library function. I have attached a picture of what my code looks like.
Please give this a try and see if it works for you. Please let me know how this goes.
Sincerely,
Feroz
(2,681 Views)
You could always cast the GOOP reference to an I32 and use this data type in your DLL.
The reference is actually only a 4 byte integer pointer passed from one GOOP method to an other and could therefore easily be casted.
Mattias Ericsson
Endevo
(2,681 Views)
