Pass .NET reference between callbacks
I have several callback VIs assigned to certain events.
One of these events returns a refnum to an object I need to work with in other callbacks later.
I have read I cannot use functional global, becouse the reference gets garbaged, but how can I do this ?
I tried to pas it through queue with no luck too.
The callback procdure is like this:
1. OnMouseEnter - here I get the hoovered object reference
2. OnMouseMove - here I want to work with the reference from 1.
3. OnMouseLeave - here I can free the reference
(2,773 Views)
Ok so,
the only ugly solution I found:
Is there any better way to recreate the object or to tell labview not to destroy it ?
(2,765 Views)
Accepted by topic author Bublina
You can create a System.Stack, push the object on and then pop it back off to get a new reference to the same object. That will work more universally than the approach you showed, which will only work for a handful of types that can be converted to a variant.
Jarrod S.
(2,743 Views)
mscorlib->System.Collections Stack
methods push, peek, pop
(2,730 Views)
