Parsing out non-numeric characters in a string
Ok thanks for the help Bill, Kudos coming your way soon!
Anyone else have any ideas to help me with my RegEx or Search and Replace Pattern problem (see previous posts for problem)?
Thanks for any help!
SM
Message 61 of 70
(2,268 Views)
Search and Replace Pattern.vi
Ben64
Message 62 of 70
(2,264 Views)
Ben,
Thanks for the reply. I have LV 2013 though... Is there a way you can make that 2013 compatible?
SM
Message 63 of 70
(2,262 Views)
Ben,
Thanks for the reply, works brilliantly.
First, I tried to repeat that same process to eliminate multiple decimal places (see attached), and it didn't really work.
Second, can you kind of explain to me the syntax for that? For instance, was does the "+" mean in the search section. For example the one with the negative sign, does the "-+" in the search portion, does it mean it's looking for more than one "-" sign?
SM
Message 64 of 70
(2,241 Views)
@Sman29 wrote:
Ben,
SM
Yes, in a regex the "+" means one or more consecutive occurence, for a litteral + sign you need to add an escape character: \+ (\++ thus mean or or more plus sign).
Ben64
Message 65 of 70
(2,237 Views)
Ben,
Ok, that makes sense. Do you know why the "." section won't work correctly? Please see attached screen shot. Also, is there a way to combine all those Search Patterns so I don't have to have so many?
And is there a way to check for additional tilde's outside the brackets? Or a non-tilde character?
Thanks for the help,
SM
Message 66 of 70
(2,234 Views)
Ok I got the decimal place working, I had to do the "\." Still though, is there a way to combine the searches so I don't have so many? Also, is there a way to check for additional tilde's outside the brackets? Or a non-tilde character?
SM
Message 67 of 70
(2,231 Views)
The . is a special character that matches any character, use \.
Message 68 of 70
(2,226 Views)
Gotcha. Is there a way to look for multiple tilde's outside the brackets, or non-tilde characters outside the brackets?
SM
Message 69 of 70
(2,218 Views)
Accepted by Sman29
I figured out the non-tilde's outside the brackets, just did [~~] and that matches any non tilde character. Attached is a screenshot of my parsing code as of now.
Is there any way at all to check the pattern and notice that if a bracket is missing, it will automatically place a bracket there?
EDIT:
Also, is there a way to make a non-numeric entry a 0? For example, if I input: "[100~BadCharacter~300]" the output would be: "[100~0~300]". Right now if I do this the output looks like this: "[100~~300]". I can't really just say replace with a 0 because if I input: "[100~Bad123Charac123ter~300]" the output would be: "[100~000123000000123000~300]" and that is just a huge number. Can I check if there is like a string only with no numbers in between?
SM
Message 70 of 70
(2,214 Views)
