Parsing out non-numeric characters in a string
The InRange? led is off meaning that the two first values are not in the range defined at index 0 and 1 of the lower limit input and were coerced (you set index 2 to -150 but index 0 and 1 are probably at the default value of 0). Also, the upper limit should be included (right click the function and select include upper limit). The code I posted is unfinished, I only included the limit check for the first block of data.
Ben64
Message 41 of 70
(2,264 Views)
Update:
I took the range checking portion off the code and it worked fine, so I guess the error is somewhere in that section. But I am not really sure what that section of code is doing, so I can't really debug it..
Also, is there a way to check if multiple decimal's or negative signs are used? Or if a non-alphabetic character was accidently put in between numbers for an element?
SM
Message 42 of 70
(2,263 Views)
Here's a way to check each element.  The result will be an empty string if it's malformed.
Jim
Message 43 of 70
(2,254 Views)
Jim,
Thanks for the replies. But I would like to parse out any bad data, not just make it 0. If this is possible, which Ben has showed it is.
SM
Message 44 of 70
(2,251 Views)
@SteMob wrote:
Jim,
SM
What exactly does that mean?  If the data is bad enough, the results aren't going to be good enough to mean anything.  It would be like me telling someone "blah blah blah",  "Oh well you know what I meant.".  You either have good data or bad data, and you are trying to take bad data and guess what the good data is supposed to be.  There is no super algorithm that is going to guess what the good data would be when you have an unlimited number of things that could go wrong.  Just return a 0 and report that the data is bad.
Message 45 of 70
(2,244 Views)
Raven,
Right, I understand that, but I would like to parse out as much as possible, at least for the more common errors like a space or too many negative signs or something. After those have been addressed, then I will just return 0 if some more advanced errors are encountered.
SM
Message 46 of 70
(2,237 Views)
Not to beat a dead horse, but you know you could've knocked out that data entry app in less time than it's taking you to figure out this RegEx stuff.
It never hurts to go to your lead with an idea that might make it easier for everyone else.  Just be respectfull and don't be a bully about it.
The worst they could so is say somethinbg like, "Well, we can't do it that way because customer requirements say blahblahblah", or something like that, and you at least gain more knowledge about how your little piece fits in with all the others.
Bill
CLD
(Mid-Level minion.)
Message 47 of 70
(2,215 Views)
Bill,
What do you mean by "data entry app"?
SM
Message 48 of 70
(2,197 Views)
What would be some additional stuff to add to the RegEx or Search And Replace Pattern such that I could parse out any extra decimal place (such as 123...456) or extra negative signs (such as ---123) or extra tilde's (such as [123~~~456~789] )?
Attached is a screen shot of my current code.
SM
Message 49 of 70
(2,186 Views)
Way back on the bottom of page three, I uploaded a snippet that contained the seed for a possible data entry application that would eliminate the possibility of command syntax error, but you replied that the powers that be wanted it done the way you had described it, so I didn't push it any further.
Bill
CLD
(Mid-Level minion.)
Message 50 of 70
(2,183 Views)
