Parse formula in Labview
Tested it with laptop on mains power and then the times are consistently around
LabVIEW 8.0: 1.25 us and 71 us respectively
LabVIEW 2016: 1.4 us and 67 us respectively
Interestingly when I just loaded the 8.0 VIs in 2016 without first saving them, the performance was terrible even if run multiple times. I came out with times of around 50 us and 270 us respectively.
Rolf Kalbermatter  My Blog
Message 21 of 22
(1,279 Views)
And don't forget that the NI parser evaluation gets slower when you add input variables. Even if those are not used. IYAM, it's a bug that variable parsing is done in the evaluation part, it should really be in the parsing.
Just saying that running benchmarks on a single use case might give the wrong impression. When I started benchmarking my parser, NI's VI's where a bit faster, until I optimized and started using more variables... Being fast is one thing, ability to scale up is something else.
Message 22 of 22
(1,235 Views)
