Pareto Chart
How to build a pareto chart in labview?
Message 1 of 8
(3,806 Views)
Hi sibangi,
to show a pareto chart you simply have to sort your data values to start with largest value first.
Then plot them in a graph and edit the plot properties to show bars…
Message 2 of 8
(3,795 Views)
But for Pareto analysis, the cumulative frequency is taken into account and also there is another line chart along with the bar chart. how to do that?
Message 3 of 8
(3,779 Views)
Hi Sibangi,
You can prepare your data as you like. When you need some cumulated values then you need to add them up…
A graph can show more than just one plot. Each plot can have ite own plot properties!
Message 4 of 8
(3,776 Views)
the tricky part will be to label each column properly
annotations may be used...
Message 5 of 8
(3,739 Views)
Hi Alexderjuengere
Could you please share your VI? Because I can not find Notizliste property node and I also don't know how to create it.
Message 6 of 8
(2,973 Views)
In English versions that is the Annotations property
"Should be" isn't "Is" -Jay
Message 7 of 8
(2,960 Views)
attached as.vi saved backed to  labview 2010 (64 bit)
correct
Message 8 of 8
(2,947 Views)
