Parcing data from uC (2)
I am sending this: "b,4.53783,4.10000,00:03:59" (confirmed with a terminal) from a microcontroller and would like to write this to a txt file.
The format should be something like this: 4.53783  4.10000  00:03:59.
What i am actually getting is this: 4.538 4.100 0.000 3.000 59.000.
Any ideas?
thanks
(3,005 Views)
Accepted by topic author gillettestm32
Hi gilette,
when you want to handle strings then you should handle strings (and not numerics!):
More recommendations:
  • use a format string of "%[^,],%f,%f,%s" to scan the received string
  • there are also format codes to scan timestamps…
  • don't use ExpressVIs (like MergeSignal) to handle your data!
  • it's called "to parse" when you analyze text…
(2,994 Views)
@GerdW wrote:
You could just use Search/Replace String to replace all of the commas with tabs.
(2,987 Views)
Hi crossrulz,
you still need to delete that first item in the list/vector/array…
(2,982 Views)
Doh...
thanks a lot
(2,963 Views)
