02-07-2019 08:26 AM
I am sending this: "b,4.53783,4.10000,00:03:59" (confirmed with a terminal) from a microcontroller and would like to write this to a txt file.
The format should be something like this: 4.53783 4.10000 00:03:59.
What i am actually getting is this: 4.538 4.100 0.000 3.000 59.000.
Any ideas?
thanks
02-07-2019 08:47 AM - edited 02-07-2019 08:52 AM
Hi gilette,
when you want to handle strings then you should handle strings (and not numerics!):
More recommendations:
02-07-2019 08:55 AM
@GerdW wrote:
You could just use Search/Replace String to replace all of the commas with tabs.
02-07-2019 08:58 AM
02-07-2019 10:59 AM
Doh...
thanks a lot
