Parallelism - widht gage
Hi friends.
I would like run three loops in different speed which one. Also have only one stop button.
In my project I am using local variable but the computer brakes always.
Reviews will be welcome for all code.
Alexandre.
(3,996 Views)
Hi alex,
it really is a problem when the "computer brakes"… 😄
Can you describe your problem more detailed? Error codes? Specific problems?
Using more locals will seldomly help. Adding zero to a number also isn't needed. Using wrong datatypes forcing typeconversion isn't preferred…
Why do you need a parallel loop just to show a numeric value?
(3,972 Views)
Hi
The big problem that I am facing is the frozen screen; the mouse cursor don't move or move slowly. Another problem is to stop the vi. I need a unique button to stop all loops.
In my project there are four while loops: 1-process the image and calculate the widht; 2-store the widht in a spreadsheet (here I need adjust the speed to store each 2 minutes); 3-display the widht (speed 1000msec); 4-show the widht in a graph (20msec).
Alexandre
(3,957 Views)
Hi alex,
it's spelled "w i d t h"…
- Loop 3 and 4 can be made into just one loop: update the numeric display only every 50th iteration!
- Loop 3 and 4 can be included in loop 1, no need to transfer a scalar value to two different loops.
- Use a notifier to transfer your data from loop 1 to loop2…
How much CPU load does your program consume? Check the task manager!
Put a wait statement in the acquisistion loop to minimize CPU load…
(3,949 Views)
Ok, width, thanks.
Please, could you give me an example code about "50th iteration" and "notifier"?
About the stop button, how can I manage to one button?
The CPU is about 80%, maybe due the linescan camera.
Alexandre.
(3,941 Views)
Hi Alexandre,
use a "quotient and remainder" operation to divide the loop iterator by 50. When the remainder is zero you execute a case of a case structure…
You already use local variables for other items. Why not use a local variable of the STOP button?
(3,929 Views)
