Parallel port for serial commuication?
Is there a way to (ab)use the built-in parallel port for communication with
an RS232 device?
(2,899 Views)
Hallo, "Stefan,
Du meintest am 19.06.00 zum Thema Parallel port for serial commuication?:
> communication with an RS232 device?
The voltage levels don't fit, and the clock rate also doesn't fit.
Viele Gruesse!
Helmut
(2,899 Views)
couldn't you use the Serial port and just get a 25 pin to 9 pin connector?
Charley
wrote in message news:394e4cc7@newsgroups.ni.com...
with
> an RS232 device?
(2,899 Views)
Parallel and Serial ports are vastly different in signaling, protocol, etc.
Check out a company called "Black Box"
They make all kinds of, well, black boxes, that convert various ports to
various other ports. I'm pretty sure they've got serial to parallel and
vica-versa.
> an RS232 device?
Best Regards,
Mike T
Mike Tranchemontagne
Consulting Applications Engineer
TeraComm, Inc.
148 Main Street
Building A, 3rd Floor
North Andover, MA 01845
877-900-TERA (8372)
978-557-9490 (FAX)
603-598-4773 (Direct Line and Cell)
(2,899 Views)
