Parallel loops subVI output
I need to read data from a few devices that I have connected via ethernet, LAN. I have multiple parallel while loops, one per device, which call the same subVI to do so. The indicators show the correct data initially, but from time to time they flicker with other values, so I believe the data of the devices might be getting mixed up upon reading. Do I have to worry if the subVI is reentrant or non-reentrant? As of now, it is non-reentrant, would that affect the output data that I am reading?
(1,968 Views)
Accepted by alphanull
I would have to see code to give any real advice.  What exactly is this common subVI doing?  Generally, I prefer having communication VIs be reentrant.
(1,945 Views)
Are you talking about indicators on the subVI or on the main program? (If on the subVI, why is the panel even open?)
What are "other values"? (Values from other calls? Zeroes? Random glitches?) Are they isolated to one device/indicator or random to all?
Does the subVI retain data between calls (feedback nodes, shift registers, etc.). What exactly does it do? How quickly does it finish?
As has been said, if multiple instances of the subVI should be able to execute in parallel, it needs to be reentrant.
We cannot help more unless we see some actual code (VIs, not pictures)
(1,940 Views)
