Parallel Port VISA write problem.
I am trying to use my computer's parallel port (LPT1) to send out DIO signal to trigger my cameras.  I read Labview's instructions to ground pins 11 and 12 to ground (24 and 25).  I used VISA write.vi to send out data, however, I received "Error -1073807339 occured at VISA write", saying that "TImed out expired before operation completed.", even when I set the time out to be 10 seconds.  Anybody know what problem I have??? Thanks very much.
(3,178 Views)
By "LabVIEW's instructions" are you referring to this document?
Can you write using the Out Port VI? This method does not require grounding the lines.
(3,172 Views)
Are you writing a single byte to the port, or a longer string?  If you specify anything longer than a single byte, then "strobing" becomes an issue.  Strobing provides a way to pass non-static information out the parallel port, such as you would do when sending data to a printer, but this also requires the device to respond in a particular way.  Make sure that you are writing a single byte (a string of length 1, where each bit of that character corresponds to a data line on the port), and tell us if you still have the same problem.
-tuba
(3,164 Views)
