How to Add Serial I/O Support
hi  all
 i have created one application in vb.net using LabVIEW Dlls in which i am performing Serial I/O operation
now when i install that application on other PC LabView Dll Does not Respond
now how can i add serial i/o support or how can i install serial i/o support indepandently with my Application ?????
(3,024 Views)
Serial I/O in LabVIEW uses VISA and you must have VISA run-time installed as well as the LabVIEW run-time engine. When you create an installer, there is an option to include serial only support which is smaller than the entire VISA run-time.
(2,995 Views)
If you are working with LabVIEW 8 you will no longer see the option to include serial only support.  You will need to install the full VISA Runtime.  It sounds to me that you are distributing a DLL with your VB application, in which case you will just need to install both Runtimes individually.
-tuba
(2,967 Views)
