PXIe-4081 accuracy calculation
Good Morning,
   I have been trying to calculate the accuracy of the DMM PXIe-4081 with the resistance 4-wire measurement , 7 1/2 digits resolution , 100 OHM range and the resistor the I am reading is 0.5 mOHM. The number that I am getting is blowing my mind and it does not make sense at all specially this should be the most accurate DMM in the industry. I am getting 1.2 mOHM. I am pretty sure that I am missing something with my calculations. Any help please
(3,226 Views)
Did you look at this document? It should give you everything you need to know about this device:
https://www.ni.com/pdf/manuals/375254d.pdf
Tim
GHSP
(3,193 Views)
Yes sir,
  That is why I feel that I am doing something wrong with my calculations somehow and I wanted a second look at the thing.
Please and thank you
(3,046 Views)
Why are you not using the numbers provided in the specification from NI? Do you think they misjudged or miscalculated something?
Tim
GHSP
(2,892 Views)
Do you mean these numbers ?
These numbers are to calculate your accuracy right?
I am using them to calculate my accuracy while I am reading a 0.5 mohm with 100 ohm range
(2,885 Views)
Hi Ziad,
what do you expect when trying to measure a 0.5 mOhm (or 0.0005 Ohm) value with a 100 Ohm range? That's just 0.0005% (or 50ppm!) of the measurement range!
So what do you expect when the DUT signal is in the same range as the accuracy specs?
Yes, that might be the case. But it's "just" a generic DMM - and apparently no device specifically made for measurement of very small resistance values.
There are other devices for this kind of measurement! Have you ever looked for "microohmmeters"?
(2,880 Views)
