Inserting/deleting rows in table
I am creating a VI where the using can add a set of values unto a table to do some task.
The VI currently works fine as it is but I would like to improve its usablility by allowing the user to 'insert' and 'delete' rows on a button click.
The functions is available under 'Data Operation' when you right-click on the table but could not find a property node that I could use to call the functions.
Is it possible to call those functions programatically?
Thanks.
(4,067 Views)
You use Insert into array and Delete from array and write it back to the table.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,059 Views)
I hope by default you have an option to insert and delete row/column by right click option.
why do you need to reinvent with button click?
(4,001 Views)
If you post code next time you are more likely to get help with your code and not just general input.
Tim
GHSP
(3,961 Views)
Accepted by topic author sherzaad
Here's how you could do this with a button interface.
aputman
(3,951 Views)
