PXI-4065
I want your help,
I want to know if I could see a PWM signal using NI PXI-4065.
Best Regard.
(2,040 Views)
Hi Emna,
You might "see" such a signal, but the readings might be senseless.
The PXI4065 is a DMM supporting DC and AC signals as written in its specs.
(2,027 Views)
Nope, it cannot measure PWM signals (other better DMM like 4081 has digitizer mode that could be used to look at PWM)
Unfortunately, you cannot measure a PWM signal using 4065.
Alternatively, you can estimate the PWM duty cycle by taking a DC measurement, this measurement when made over complete PWM cycles will result in an average-DC value.
For example, your PWM frequency is 50Hz 5V TTL signal
You can configure your DMM to measure DCV with 20ms aperture time, this way it measures the average-DC over a single PWM cycle, you can compute the duty-cycle based on measured average DC value against the signal voltage range, if you measure 2.5V then it is 50% duty cycle
Santhosh
Soliton Technologies
(2,022 Views)
