02-02-2008 06:22 AM
02-02-2008 08:48 AM
02-04-2008 12:59 PM
02-04-2008 03:26 PM
Hi Devender,
It is a good thing that you are not using auto-range, as each measurement could then take up to 15 seconds. A few clarifying questions though:
The 800 milliseconds that you are taking to measure a resistance, does that include switching and settling time after you make a connection or just the DMM Read? Second, are you using one of the LabVIEW Modular Instruments Example programs? If not, I would suggest looking at the Synchronous Scanning and Handshaking examples. These can be found in LabVIEW by navigating to the Help Menu>> Find Examples>> expanding the Hardware Input and Output folder>>expanding the Modular Instruments folder>> and then looking in the NI-Switches file.
Hope this helps, Mallori M.
