PWM timing issue
I am using a NI USB6251 and I want a 50Hz signal on all 4 lines, duty cycle of 20%. This would allow me to pulse 4 LEDs in a desired order.
Message 21 of 22
(429 Views)
yes, you can output PWM signals on DO pins. They support hardware timing with upto 1MHz clock, so you just use them to output digital waveforms representing your PWM signal...
Message 22 of 22
(427 Views)
