PWM rectifier on FPGA
Hie everyone.
I have an issue with generating duty cycles for a 3 phase PWM rectifier connected to a Permanent Magnet Synchronous Generator. I am using the SVPWM and PWM VIs from Softmotion module to generate the pwm signals for the rectification. My problem is that whenever I activate PWM switching, I always get the same duty cycle for the top switches of each phase. My question is, "Is it ideal to use the Softmotion VIs to generate pwm signals for rectification, even though they are designed for motor control?"
Any feedback is appreciated
Message 1 of 1
(328 Views)
