PWM Frequency reading with USB-6341
I'm programming a test software for an EV Charger, and one of the things I need to check is if the PWM generated by te board has a frequency between 970 and 1010 HZ.
Is there any way I can measure this with my USB-6341? I'm at a loss because I usually just check voltage levels with analog readings and the state of different digital inputs for the other test softwares I've developed.
Thanks in advance!
(1,189 Views)
Hi Chamorrix,
The USB-6341 offers 4 "general purpose" counters, so you can easily measure frequencies using your DAQ device!
(1,171 Views)
Thank you that's nice to hear I wasn't even sure what to look for as I'm relatively new to this, do you happen to know where I could find some example to check on how to configure a counter?
(1,164 Views)
Accepted by Chamorrix
Hi Chamorrix,
There is one place in LabVIEW where you find example code: use the ExampleFinder in the help menu!
(1,152 Views)
