PROPERTY NODE
Trig wrote:
sorry i havent created the property nodes or references yet. i just want to connect the VI inside of a VI (subVI) nodes to the vi on the main block diagram. Yes,main block diagram is the area outside the loop.
Use a wire!
It still isn't clear what you want.  What are you really trying to do?  Perhaps you can give more of a description of the big picture so that we know what problem you are trying to solve and give you an idea of what might actually work.
Message 21 of 21
(438 Views)
