PN sequence Generation
How to generate a PN sequence in LABVIEW. PN pseudorandom sequence generates a sequence of pseudorandom binary numbers. A pseudonoise sequence can be used in a pseudorandom scrambler and descrambler. It can also be used in  spread-spectrum system.
Message 1 of 13
(12,410 Views)
Is there a reason that you can't use LabVIEW's built in random number generator? It is by definition (I researched this about 12 years ago, am fuzzy about the details) a PRN generator. Now if what you are looking for is something that generates a predictible, repeatable PN, well don't think it would work in that case.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2 of 13
(12,408 Views)
The NI Modulation Toolkit has that feature.
Randall Pursley
Message 3 of 13
(12,384 Views)
PRNGs (aka PRBS) are usually based on Linear Feedback Shift Registers (LFSRs) so a search on LFSRs is a good idea to see the theory behind them.
One difference with LFSRs and the LabVIEW "dice" (which does output pseudorandom numbers) is that LFSRs can't output an all zero state. A seed value is used to start the sequence (and this can't be all zeros either).
Here is an 8 bit LSFR:
Note that the rotate array function is only there for aesthetic purposes.
The same output will always be returned for a given seed value and iteration count of the For loop.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 4 of 13
(12,349 Views)
Respected sir,
how 511 pn sequence can be truncated to 500 ?
With regards
Message 5 of 13
(11,017 Views)
I'm not sure what you are asking here:
So you have a PN sequence of 511 items and you want to reduce this to 500 items?
How is your sequence generated (attach code if possible)?
Assuming your sequence comes in an array, couldn't you just use Reshape Array to remove the extra items?
steve
Message 6 of 13
(10,996 Views)
Respected sir,
After generating a pn sequence of n=9 ,length=2^n - 1=511 , i need to reduce this length to 500, by truncating the last 11 MSB's of this sequence. What is the possible solution for this ?
thnx,
with regards
Message 7 of 13
(10,981 Views)
Your data is an array of length 511, run it through a "Delete from Array" function, deleting either the last 11, or last 500, depending on which end of the array is the 500 elements you desire. In the first instance the resulting "main" array output will be the first 500 elements, in the second the "deleted" output will have the last 500 elements.
Putnam
LabVIEW Champion
Message 8 of 13
(10,977 Views)
I am obliged for this solution, sir.
Thank you.
Message 9 of 13
(10,967 Views)
sorry sir , may i ask the components in your PN sequence . I didnt fint a component  right from  Reverse 1D Array . What the name component this?
Message 10 of 13
(10,412 Views)
