PID tuning array instance
Hi
Right, I will see what vis are missing and get them too you immediately.
what can I give you regarding the camera setup?
The cameras are two Hikrobot MV-CA013-20GM cameras and one Hikrobot MV-CA013-20GN cameras communicating via a GigE connection.
I ill try to get a MWE version to you as soon as i can.
Best Wishes
Andrew
Message 31 of 65
(2,907 Views)
Hi Andrew,
when opening the only lvproj file in your ZIP then the one and only VI referenced in this project is missing:
When opening some of those other VIs in that folder they also claim for missing subVIs…
What's so hard to maintain all related files in one folder and in one lvproj project file?
Message 32 of 65
(2,906 Views)
I got the same.
Message 33 of 65
(2,895 Views)
Hi Gerd and Wiebe
Im very sorry I have made a very stupid error. Give me a few moment to clear my mind and sort this mess out.
Best Wishes
Andrew
Message 34 of 65
(2,887 Views)
Hi both
I have tried to put everything into one folder but apparently even as a zip file, it tells me that its too large. Is there another alternative?
Message 35 of 65
(2,870 Views)
Hi Andrew,
Well, when the resulting ZIP file is too large, then you probably didn't create a "MWE"… 😉
Message 36 of 65
(2,868 Views)
I have made a minimum version I think, how can i copy all the dependencies into 1 folder without having to dig them all up
Message 37 of 65
(2,857 Views)
Hi Gerd
try this one and let me know how it goes. 🙂
Best  wishes
Andrew
Message 38 of 65
(2,854 Views)
I think our ideas about minimum are different 🙄.
We cannot run this code. Even if I had IMAQ installed, I wouldn't have the camera setup. How are we ever going to test values coming out of a PID without even valid inputs?
For a MWE (in this case, something that shows your error in the PID) I'd expect the PID VI and a VI that calls it. Nothing else.
BTW and OT:
At this time of your development, you might have a look at OO. It seems that the way you treat your camera (as an object) is very OO-ish. Putting all camera stuff in a camera class, and all camera data in the class's private data is pretty much what you're doing now, but with a class it will actually be nice. The camera is just one example, but very exemplary.
Once you have it working (and a good understanding of OO), it would be very (very) easy to make a child class that simulates the camera. That way, you can very easily switch between real camera input and a recording. As a bonus.
Message 39 of 65
(2,841 Views)
Hi Wiebe
I will send you the PID vi, with some image data then. What is OO?
I have never heard of this term before?
Best Wishes
Andrew
Message 40 of 65
(2,837 Views)
