PID simulation
Hello I am new in labview, I want to simulate this pid controller , using the values of kp = 12, Ki= 12.6316 and Kd = 7.6 ,  on the basis of mentioned gain values ti and td are calculated.
On running it I am getting such response
But this is not correct  as , implemented the same  thing in scilab and got response below.
Below is implementation in scilab
Please help..
(3,515 Views)
Hi All
I  want to do time domain analysis of below system, I want to find settling time, rise time ,  etc.
Please help
(3,474 Views)
Hi krishna,
  1. write down all the formulas you need to determine your data.
  2. implement those formulas in LabVIEW!
Where are you stuck?
Do you really have a plant where you use PI gains of 2e-9 and 1e+20???
(3,465 Views)
Yes I do have a plant , I want to  measure rise time , settling time, peak overshoot , peak time  etc for this
(3,450 Views)
that  is T i =  1e+20 , means  Ki is set to zero.
(3,449 Views)
Dear krishna_das,
https://www.intechopen.com/chapters/75407 I've found this article that is about labview data analysis functions. You can find what could help your case and use it. I guess you should do the analysis on the cluster that is depicted as a xy graph.
(3,382 Views)
