PID pressure control implementation
Hi.
I am trying control pressure drop on my hydraulic Rig.
Concept is to control  pressure drop across two port. To achieve that I am reading pressure from two pressure transducers P1 P2 callcultaing
delta P and send it to PID module.  Output signal is connected to proportional relief valve (demand signal 0-10V) to control rig pressure.
I have attached my VI. I haven't tried it yet as I want to make sure I won't damage the rig.
Thanks.
(3,762 Views)
Hi gregorian,
- you didn't set any PID gains so far: determine them before starting the PID control loop!
- you should read the AI channels in "n chan 1 sample" mode…
- why do you use ExpressVIs to create the chart? Use BuildCluster instead as is shown in the context help of the chart…
Did you try to control your test rig manually? Maybe in a safe steady state?
What happens when you change the voltage signal for your valve (in small steps)? This would also help to determine PID gains…
How fast do you need to control the rig?
Does the control system show a linear behaviour? Is the behaviour very non-linear? In case of (very) non-linear behaviour you might think about gain scheduling and an additional bias-forward control…
(3,747 Views)
Thank you for your quick reply.
I think I have sorted these.
I will come back to the rig tomorrow and will gather more information.
(3,731 Views)
Hi gregorian,
Nope…
- Now you use "1 chan N sample" mode, which clearly is wrong when you want to read 2 channels…
- Btw. you can select two channels with just one DAQmxChannel control…
- Why do you use "Build Cluster Array" when the context help shows you to use a Bundle node?
(3,721 Views)
Hi.
Thanks.
I have tested the rig it is fairly proportional (pressure vs command signal) also attached data.
I have never tuned PID controller before could you.
What would be the next step to find right gains values?
I would be appreciated if you could help me.
It is very struggling at current setup and after 10-20 sec starts oscillating.
Thanks.
(3,710 Views)
Hi gregorian,
- Above 3V/30bar the system is rather linear, below you should use a different set of PID gains. (Or don't use your test rig in this pressure range…)
- just for the upper pressure range: for a change of 1V the pressure changes ~35bar, so your P gain should be in the order of 1V/35bar ~= 0.03.
- from the measurement data I cannot tell about I gain: here you need to measure a step response.
Basic PID stuff:
- Have you ever heard of Ziegler and Nichols?
- Have you read the Wikipedia article on PID controls?
(3,698 Views)
