PID controller for Temperature control
I am going to build PID controller for temperature control. I am going to supply voltage (Keithley 2400) to heating element and to measure temperature by thermocouple NI-USB-TC01. Here is my question:
1. is it possible to connect Keithley 24xxx PID controller ?
2. Do I need DAQ module or it is possible to  manage it without DAQ ?
I appreciate any suggestion.
(2,569 Views)
Hi Dudoni,
  1. What is a "Keithley 24xxx PID controller"?
  2. You already have a DAQ device to read the TC temperature value, so you can manage your task using the devices you already have!
In general you can implement your control loop using the USB-TC to read the pv (process value) and the K2400 to output the co (control output).
(2,549 Views)
Thank you for your answer.
1. I meant. Can I control power supplier Keithley 2400 by DIP controller.
2. As i know NI USB- TC01 can be read by Labview without any DAQ device.
Last week, I built power supply controller fro Keithley 2400 and I was thinking can I build PID controller to connect power supply and Temperature sensor.
BR
Dudoni
(2,537 Views)
Hi Dudoni,
  1. Yes, you can implement your PID control using those two devices.
  2. The USB-TC also is a DAQ device…
(2,532 Views)
Hello
I connected to PID controller but there is smth wrong. (picture below)
The main idea of program is when we apply 2,8 V to heating element,  temperature of heating element should increase 130 degree.
If T> 130 degree
Power supplier = off
else T < 130 degree
Power supplier = on
or I can control it without PID ?
(2,467 Views)
Hi Dudoni,
If T> 130 degree
else T < 130 degree
Power supplier = on
Why do you need a PID for such a simple ON/off approach???
Why do you need to initialize the Keithley in each iteration?
Why do you need to close the Keithley communication in each iteration?
Why do you need to switch the Keithley on/off in each iteration???
Why do you connect the Keithley output to the PID pv input?
Why do you work with DDT wires and why do you connect that DDT wire to the PID sp input? Do you notice that coercion dot?
What is the purpose of that "plant" subVI?
Did you determine meaningful PID gains?
(2,462 Views)
