‎06-11-2004 12:39 PM
‎06-13-2004 10:04 AM
‎06-14-2004 09:03 AM
‎06-14-2004 10:11 AM
‎06-14-2004 12:39 PM
‎06-14-2004
03:15 PM
- last edited on
‎09-10-2026
12:07 PM
by
Content Cleaner
Hello tschopper,
Which Pocket PC operating system are you using? With a Pocket PC 2002 device, you should be able to follow the installation instructions in the PDA Module Release Notes under the installation section. Because a newer PDA module recently released, but you are still using LabVIEW 7.0, make sure to use the reference material for the older PDA module.
Most newer PDA devices use the Pocket PC 2003 operating system. If you are using Pocket PC 2003, use this Knowledge Base [link removed; article no longer available] as a guide for the necessary installations. You can
substitue the newer eVT 3.0 SP 3 for steps 4 and 5.
This process, though difficult, definitely works if you follow the directions closely and in exact order. I currently have LabVIEW 7.0 on my machine and I can target both PPC 2002 and 2003 devices after following these installation steps.
I hope this helps!
Liz F
