PCI to UART
I will be using Oxford Semiconductor chip  OX16PCI952 ( PCI to UART ) for a project.  Oxford will provide the drivers for the chip, so I guess it will be recognised by Windows, and pop up in the device manager  tab under control panel. I am wondering if I can see these COM ports in Labview, if I run one of the example VIs provided ( basic_serial.VI)
Thank you
Message 1 of 8
(4,362 Views)
If the device shows up as a Com port in Windows, then there is no reason why Labview won't recognize it as a Com port as well.
Message 2 of 8
(4,356 Views)
Hi BIRA_PXI,
You will need to have NI-VISA installed to communicate with a serial port. Here is a link to download the latest version of NI-VISA, which is version 4.1. Let us know if you have any specific questions!
Message Edited by MissyD on 05-24-2007 06:55 PM
Missy S.
Project Engineer
RoviSys
Message 3 of 8
(4,333 Views)
Hi Missy D,
Thanks for youir reply. The Oxford Chip, has two UART channels, COM0 and COM1. I just need one for my application, and I wanted to mask the other one from showing in Labview, under the I/O resource name. For Example, when I insert the card with the oxford chip, it should just show COM0 or COM1 instead of BOTH COM0 and COM1. Is there any way in Labview that I can do this.
Thanks for your help.
BIRA_PXI
Message 4 of 8
(4,243 Views)
Message 5 of 8
(4,232 Views)
Hi Bira_PXI.
May I know where do you reside?
Are you located in ASEAN region?
I'm looking for some information on Oxford...
Just to check, where do you obtain the device.
Message 6 of 8
(3,994 Views)
Hi OcenViper,
I am located in US. We usedTRGcomponents to source the chips. If you are not able to get Oxford, then try Moschip semiconductors. They are based in India.
birapxi
Message 7 of 8
(3,976 Views)
Hi there.
Thanks for your reply and advice.
Will check out there....
Thanks again.
Message 8 of 8
(3,963 Views)
