Activex control ocx basics
Hello everybody,
    I am new to activex control,
can anyone tell the procedure to use it in labview,
i tried to regidter the ocx file through regsvr32 but it didnt worked
thanks
Regards
Shrekt
Message 1 of 8
(4,106 Views)
What activex control is this?
When you say that regsrv32 didn't work, was there an error message?
Message 2 of 8
(4,104 Views)
Thanks for the quick reply
Actually i dont know the procedure, and it can be any control, in my case i have downloaded progress bar ocx file from net.
Can you list down the procedure, it would very helpful.
Shrekt
Message 3 of 8
(4,090 Views)
I am no expert in this but this page seems to explain it:
http://en.wikipedia.org/wiki/Regsvr32
Message 4 of 8
(4,083 Views)
I didint understood what  to do after i register it
how can i then use the ocx file.
elaborate it
thanks for cooperation
Regards
Shrekt
Message 5 of 8
(4,052 Views)
HI
In LabVIEW help go to Fundamentals >Windows Connectivity >Concept>Using Activex with LabVIEW
This help also link to examples
Hope this helps
Regards
San
Message 6 of 8
(4,047 Views)
If the registration worked, then go to the front panel add a ".NET and Active X" ->  "ActiveX Container" control to your block diagram. then right-click on it and choose "Insert ActiveX control". A dialog box will appear and in the drop-down, hopefully your OCX control will be listed (with it's full name, not the filename).  Sometimes it depends on which specific control it is (which you have not yet mentioned).
Message 7 of 8
(4,046 Views)
The file did'nt show in the list what can be the possible reason?
Message 8 of 8
(4,037 Views)
